Roymech engineering encyclopedia
Hand Grasping and Grip Size
These photographs illustrate how the human hand grasps objects of different diameters. They provide a visual reference for engineers considering the size of handles, knobs, hand controls and other components that must be gripped or manipulated by an operator.
The examples show an average adult male hand gripping objects from approximately 10 mm to 175 mm across. As the object size increases, the hand changes progressively from a finger or precision-type grip to a whole-hand grip and eventually to a more open grasp.
The photographs are illustrative rather than dimensional design limits. Hand size varies considerably between individuals, and grip requirements should be considered for the intended user population. For percentile hand dimensions, see anthropometric data and human body dimensions.
Hand Grip and Object Size
The diameter and shape of an object influence how it can be grasped, the fingers that can contribute to the grip and the amount of force that can comfortably be applied.
Small objects may be controlled primarily using the fingers and thumb. As object diameter increases, more of the hand becomes involved and the grip develops towards a whole-hand or power grip. At still larger sizes, the fingers may no longer be able to wrap around the object and the available grip can become increasingly dependent on friction and hand span.
This is important when designing handles, handwheels, knobs, tools, containers and removable components. A component that can physically be grasped is not necessarily comfortable or suitable for frequent operation.
Hand Grasp
Using Grip Size in Engineering Design
Grip dimensions should be selected according to the task rather than from hand size alone. Factors to consider include the required force, precision, frequency and duration of use, wrist and arm posture, surface condition and the shape of the object being handled.
Where a significant operating force is required, the design should generally allow an effective grip without excessive finger loading or an awkward wrist position. Tasks requiring fine control may require a different grip geometry from tasks requiring relatively high force.
Gloves and other personal protective equipment can significantly affect grip. They may increase the effective hand dimensions while reducing dexterity, tactile feedback and the ability to apply force. This should be considered where equipment is intended to be operated while wearing gloves.
Frequency and duration are also important. A grip that is acceptable for an occasional operation may not be appropriate for a task repeated many times during a working shift.
Grip Size, Strength and Controls
Object size is only one part of hand-interface design. The force that an operator can apply depends on the type of grip, hand and arm position, individual strength and the mechanical arrangement of the control or tool.
For information on gripping forces and human capability, see human strength and endurance. For dimensions and operating forces associated with knobs, levers, push buttons and handwheels, see machine interfaces and controls.
Engineering Design Considerations
When designing equipment that must be grasped by an operator, consider:
  • The hand sizes of the intended user population.
  • Whether a precision grip or whole-hand grip is required.
  • The force or torque that must be applied.
  • The frequency and duration of the task.
  • Wrist, elbow and shoulder posture during operation.
  • Surface shape, texture and available friction.
  • Whether gloves or other protective equipment will be worn.
  • The consequences of slipping, losing grip or operating the equipment incorrectly.
The photographs on this page should therefore be used as visual engineering guidance rather than as prescribed ergonomic limits.
See Also
