Roymech engineering encyclopedia
Human Access Space Requirements for Engineering Design
Solid Print 3D
This page provides engineering guidance on human access space requirements, including clearance, reach and working space for maintenance and operation. The data supports ergonomic design of equipment, workspaces and access routes to ensure safe and effective human interaction.
For operator interaction and control placement, see machine interfaces and control design.
Access space design should be considered alongside anthropometric data, human strength and work and energy requirements.
Man Access Space Requirements
This page includes a number of figures illustrating approximate man access requirement.  The dimensions are only for guidance and are based on USA adult male (95% percentile).
Note: These values are indicative and based on historical datasets. Modern design practice typically considers a wider population range including female and international anthropometric data.
Minimum Area Entry Widths
  • 0.330m to 0.45m .... Difficult For 1 Man
  • 0.450m to 0.6m .... Reasonable For 1 Man
  • 0.6m to 0.9m .... Good For 1 Man
  • > 0.9m .... Good For 2 Men
Body clearance for prone access
man prone
Body clearance for kneeling man
Man Kneel
Body clearance for crawling man
Man Crawl
Body clearance for squatting man
Man Access Squat
Maintenance reach levels
Maintenance Acces
Ramp Access
Ramp
Stairs
Staris
Step Ladders
Step Ladders
Ladders
Ladders
Miscellaneous
Frequently Asked Questions
What are human access space requirements?
Human access space requirements define the minimum clearances and working space needed for people to safely access, operate and maintain equipment.
Why are access space requirements important?
They ensure that equipment can be safely used and maintained without causing injury, excessive strain or restricted movement.
What factors affect access space design?
Access space depends on body size, posture, reach, strength and the type of task being performed.
Are these values suitable for detailed design?
No, these values are indicative and should be validated against relevant standards and project-specific requirements.
See Also
