Roymech engineering encyclopedia
Anthropometric Data and Human Body Dimensions
This page provides anthropometric data and human body dimensions based on 5th, 50th and 95th percentile measurements. The data can be used as a reference when considering ergonomic design, workplace layout, equipment dimensions, reach and access requirements.
Anthropometric data should be used alongside human strength and endurance data, human work and energy and human access space requirements when designing equipment and workspaces. Additional dimensional guidance is available on the human related dimensions page.
For the design of controls and operator interfaces, see machine interfaces and control design. For hand grip arrangements, see grasping and hand grip examples.
Safety Note: The following anthropometric data is provided for general engineering guidance and preliminary design. For safety-critical or detailed applications, suitable current standards and anthropometric data for the intended user population should be used.
Using Anthropometric Data in Engineering Design
Anthropometry is the measurement of human body dimensions. Engineering applications include the design of machinery, workstations, access openings, controls, seating, maintenance spaces and other equipment intended for human use.
Human dimensions vary considerably between individuals and populations. They can also vary with age, sex and the population from which the data was obtained. Anthropometric datasets may also change over time as populations change.
The intended user population is therefore important. Equipment intended for a specialist group may require different anthropometric data from equipment intended for the general population.
Clothing, footwear, gloves, protective equipment and tools may also increase the space required by an operator and should be considered separately where appropriate.
Understanding Anthropometric Percentiles
Anthropometric dimensions are commonly expressed using percentiles. A percentile describes the proportion of the reference population below a particular measured value.
  • 5th percentile — approximately 5% of the reference population has a smaller measured dimension.
  • 50th percentile — the median value; approximately half of the reference population is below this value and half is above it.
  • 95th percentile — approximately 95% of the reference population has a smaller measured dimension.
The range from the 5th to the 95th percentile therefore represents approximately the central 90% of the reference population for that particular body dimension.
The 50th percentile is the median of the measured population and should not be assumed to be the arithmetic mean of the 5th and 95th percentile values.
Selecting the Appropriate Percentile
Designing equipment for the 50th-percentile or “average” person is rarely sufficient. The appropriate anthropometric percentile depends on the particular engineering requirement.
Design Requirement Typical Anthropometric Consideration
Reach to controls or equipment Smaller users may determine the limiting requirement
Doorways, openings and body clearances Larger users may determine the limiting requirement
Workstations and adjustable equipment A suitable range of the intended population should be accommodated
Operating forces Users with lower strength capability may determine the requirement
Structural loading by personnel Larger or heavier users and appropriate engineering design factors may govern
Different dimensions within the same design may therefore require different percentiles. For example, a control may need to be positioned so that a smaller operator can reach it, while the surrounding access space may need to accommodate a larger operator.
Anthropometric Data Table
The following anthropometric data relates to British adults approximately 19 to 65 years of age and provides 5th, 50th and 95th percentile body dimensions. Dimensions are in millimetres unless otherwise stated.
The data is based principally on anthropometric information published in Stephen Pheasant's Bodyspace: Anthropometry, Ergonomics and the Design of Work, subsequently updated with Christine Haslegrave.
The data relates to people wearing minimal clothing and no footwear. The original RoyMech guidance suggests allowing approximately 25 mm for male footwear and approximately 45 mm for female footwear where footwear height is relevant. Appropriate allowances should be determined for the actual user population and application.
Standing human anthropometric dimensions
Human anthropometric dimensions
Seated human anthropometric dimensions
Human reach and body dimensions
Human body dimension reference diagram
Dimension Men — Percentile Women — Percentile
5th 50th 95th 5th 50th 95th
1 — Height 163017451860 151016201730
2 — Eye Height 152016401760 141015151620
3 — Shoulder Height 134014451550 124013301420
4 — Elbow Height 102011001180 95010201090
5 — Hip Height 8509351020 750820890
6 — Knuckle Height (Fist Grip Height) 700765830 670720770
7 — Fingertip Height 600675730 560620680
8 — Sitting Height 860915970 800855910
9 — Sitting Eye Height 740800860 700750800
10 — Sitting Shoulder Height 570615660 530580630
11 — Sitting Elbow Height 210250290 190235280
12 — Thigh Thickness 130155180 120150180
13 — Buttock-Knee Length 560605670 520585650
14 — Buttock-Popliteal Length 450510570 440500560
15 — Knee Height 490535580 460500530
16 — Popliteal Height (Lower Leg Length) 410450490 370410450
17 — Shoulder Breadth (Bideltoid) 440485530 390440490
18 — Shoulder Breadth (Biacromial) 370405440 340365390
19 — Hip Breadth 350390430 350405460
20 — Chest Depth 210245280 210250290
21 — Abdominal Depth 220275330 200270340
22 — Shoulder-Elbow Length 330365400 300330360
23 — Elbow-Fingertip Length 440475510 400430460
24 — Upper Limb Length 730790850 650715780
25 — Shoulder Grip Length 680745810 620685750
26 — Head Length 190200210 170185200
27 — Head Breadth 140155170 140150160
28 — Hand Length 170190210 160175190
29 — Hand Breadth 8090100 708090
30 — Foot Length 240265290 220240260
31 — Foot Breadth 90100110 8090100
32 — Span 167017451950 152016501780
33 — Elbow Span 8709451020 780845930
34 — Vertical Reach 195021002250 181019402070
35 — Vertical Reach (Sitting) 122013051390 110011901280
36 — Forward Grip Reach (Standing) 720790860 660725790
Hand Dimensions and Grasping
Hand dimensions are important when designing handles, controls, tools and equipment that must be grasped or manipulated by an operator. The main anthropometric table above includes hand length and hand breadth for male and female 5th, 50th and 95th percentile values.
Grip design also depends on the type of grasp, required operating force, task duration, frequency of use and whether gloves or other protective equipment are worn.
Human hand grasp and hand capacity dimensions
See grasping and hand grip examples for additional illustrations of common grasping arrangements.
For grip and operating-force capability, see human strength and endurance.
Human Reach
Reach dimensions are important when positioning controls, handles, tools, maintenance points and other equipment that must be accessed by an operator.
Maximum physical reach should not automatically be treated as a suitable working reach. A person may be physically capable of reaching a position while the resulting posture is unsuitable for frequent or prolonged work.
For frequently performed tasks, equipment should preferably be positioned within a comfortable working region for the intended user population. Occasional operations may permit different reach criteria following appropriate assessment of posture, force, frequency, duration and the consequences of the task.
When determining whether an operator can reach a control or component, smaller members of the intended population will often determine the limiting reach requirement.
Maximum Height of Reach
The original RoyMech guidance gives the following very general relationship:
Maximum height of reach ≈ 1.24 × body height
This should be regarded only as a general relationship. Actual reach depends on individual body proportions, posture, shoulder movement, the type of reach and whether fingertip contact or a functional grasp is required.
Sex Stature Percentile To Fingertip (mm) Grasping Height (mm)
Male Tall 95th 2310 2190
Male Average 50th 2180 2060
Male Short 5th 2040 1920
Female Tall 95th 2120 2020
Female Average 50th 2000 1900
Female Short 5th 1890 1790
Reach, Access and Working Space
Reach and clearance are different engineering requirements. Reach may be governed by smaller operators, while access openings and clearance around the body may be governed by larger operators.
The required design envelope can also increase when operators wear protective clothing, gloves, helmets, respirators or other personal protective equipment.
Specialised equipment may introduce additional constraints. For example, work through fixed access positions or glove ports can restrict shoulder, elbow and wrist movement and may reduce comfortable working reach compared with unrestricted reach.
For further information on workspace layout, body clearance and access, see human access space requirements.
Engineering Design Considerations
Anthropometric data should be applied according to the engineering function being designed rather than by selecting a single percentile for the entire design.
The intended population, clothing and protective equipment, posture, frequency and duration of the task, required strength and the consequences of poor access or operator error should all be considered.
Human-factors guidance should also be considered alongside applicable safety, security, maintainability and operational requirements. Mandatory requirements should be distinguished from recommendations and general ergonomic guidance.
Where adjustment can reasonably be provided, adjustable equipment may allow a much wider range of users to work comfortably than equipment designed around a single fixed anthropometric dimension.
References
Pheasant, S. and Haslegrave, C.M., Bodyspace: Anthropometry, Ergonomics and the Design of Work.
The edition and publication date associated with the original RoyMech dataset should be confirmed against the original source before adding specific bibliographic details.
Frequently Asked Questions
What is anthropometric data?
Anthropometric data consists of measurements of the human body such as height, reach, limb length, hand dimensions and body breadth. The data is used in engineering and ergonomic design to help equipment and workspaces accommodate the intended users.
What do the 5th, 50th and 95th percentiles mean?
The 5th percentile indicates that approximately 5% of the reference population has a smaller measured dimension. The 50th percentile is the median, and the 95th percentile indicates that approximately 95% of the reference population has a smaller measured dimension.
Should equipment be designed for the 50th-percentile person?
Not generally. The appropriate percentile depends on the design requirement. Reach may be governed by smaller users, while clearances may be governed by larger users. Adjustable equipment can often accommodate a wider range of the intended population.
Can anthropometric data be used directly for detailed design?
The data on this page is intended as general engineering reference information. Detailed or safety-critical design should use appropriate current anthropometric data, standards and requirements for the intended population and application.
See Also
